Resolved 89 convertible electrical issues
Ncarter
17
Michigan
Power windows, locks and mirrors just stopped working. No power to the driver side door. Checked all fuses and they were fine. Tried following a wiring diagram that showed a pink wire as the power source, no luck. Also looked for loose connections. I am wondering where all three items are tied together. Anyone have some ideas ?
thanks
Power windows and door locks feed from the 20A circuit breaker on the starter relay. The silver box. The lumbar for the seats also comes off this, so if your lumbar motors aren't working as well, it's a pretty good sign there's an issue at the circuit breaker, or you have a huge draw on it that is keeping it tripped out.
The power mirrors are fed from fuse 8. 15A fuse that is part of the courtesy lights. Pull the mirror switch and test the light green/yellow stripe wire to ground. Should have 12V
