89 Foxbody, AC and smog delete?
Need more info
Best solution is to run string around your pulleys and measure. WAY too many combos depending on how you deleted your A/C and smog, and what pulleys you have.
this is how I did mine! there are so many different combinations! a smog pump delete pulley is the easiest way, and you retain the original belt, that is assuming you havent already deleted the a/c!
