89 gt conv
  • Thread starter Thread starter vernkess
  • Start date Start date Feb 4, 2011
V
vernkess
  • Feb 4, 2011
how do i tighten up my doors. do imove the posts. thanx . pwilly
1987LXragtop
837
Just outside Philly PA
Feb 4, 2011
  • Feb 4, 2011
gotta replace the pins and bushings in the door hinges. cheap fix.
Flavadave4
1,044
21
49
Utica, NY
Feb 4, 2011
  • Feb 4, 2011
Yup, cheap but you have to cut out the factory pins which can be a pain in the butt.
1987LXragtop
837
Feb 4, 2011
  • Feb 4, 2011
yep. I went thru 4 blades on my dremel. Ball breaker it was.
stykthyn
5,232
2,652
223
gainesville
Feb 4, 2011
  • Feb 4, 2011
Use a router bit on your dremel. It will eat right through the pins.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 5, 2011
  • Feb 5, 2011
Hinge pin & bushing kits are available at many auto parts stores. Or see Texas Mustang Parts   //   Waco, Texas or mustang-unl.com. Usually less than $8 for the kit with one pin & 2 bushings.
The hard part is to get the old pin out. Some were spot welded in, others were hammered so that the end mushroomed. Either way, it takes a grinder or cutter bit in a drill or Dremel tool to cut the pin or grind off the weld. Once it is off, tap the pin out with a hammer and pin punch. Only remove one pin at a time so that you don't have the full weight of the door to manage. I highly recommend that you have a helper standing by to hold the door.
Once the old pin is out, lower the door and tap out the old bushings. Put the new bushings in and have the helper lift the door in place so that you can slide the new pin in. It may have to go in differently from the way it came out. That's OK, as long as you put the cotter pin in the hinge pin.
OOOPS!!!The important thing to remember is that the hinge pin isn't supposed to move once you are finished. If it does, then you will end up like me - the pin moved, it wore the door hinge instead of the replaceable bushings. Now in order to fix it right, I have to remove the whole thing again and drill out the hinge to the same size as the bushing and use 2 sets of bushings in each hinge rather than one set.
The fix for the OOOPS was very time consuming and if you aren't up to some very interesting machine work, do it right so you won't have to do it again. I fixed the OOOPS but I had $43 worth of drill bit and specialized reamer plus pulling the fender off to fix it.
V
vernkess
  • Feb 5, 2011
problem is not with the up and down. itis the in and out or how the #$%$# else cn i explain.
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Feb 5, 2011
  • Feb 5, 2011
With a wrench.
Seriously....be a little more descriptive. We aren't going to guess
V
vernkess
  • Feb 5, 2011
ok if i stand outside the car and push on door it moves in and out.
too much slack.
fiveohwblow
Official Member
2,169
145
155
Feb 5, 2011
#10
  • Feb 5, 2011
  • #10
too much slack.
While closed?
V
vernkess
#11
  • Feb 5, 2011
  • #11
yes while closed
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Feb 5, 2011
#12
  • Feb 5, 2011
  • #12
How are then bushings on the strikers?
If they are worn, auto zone sells replacements in the Help! Section for $8 a side.
giddyup306
3,041
Feb 6, 2011
#13
  • Feb 6, 2011
  • #13
Quick questions:
Why does it in the Talk forum show me as the author of this post?
Why did my original post to this tread not show up in this thread?
V
vernkess
#14
  • Feb 11, 2011
  • #14
:thanx will look at auto zone vern:
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
Electrical Dash wiring
  • RileyDymond
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 19, 2026
RileyDymond
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
