89 LX backfireing intermittenly
  • Thread starter Thread starter stevesLX
  • Start date Start date Mar 11, 2007
stevesLX
373
cincinnati
Mar 11, 2007
  • Mar 11, 2007
Not sure what is causing this but I keep getting back fire as I am driving down the road and its loud. What it does is you can take off and the car will run like a bat out of hell but then you can slow down or come to a stop and take off again and it feels like someones holding you back and if you keep your foot in it it will start to backfire. Its back and forth with this. Anny help would be appreciated. I installed new o2 sensors and a new TPS. My timing w/ the spout out is set at 14 degrees I even tried bumping it up to 18 and it still acts the same. Even at 10 degrees it does it. Now I have been having a lot of valvetrain issues with trying to get rid of my valve train noise but I don't think it causing this. My preload on my lifters is at .070 which crane cams said was fine. But like I said I dont think its causing this thing to run fine one minute and likme crap the next and backfiring.
illnotch
Toronto, Canada
Mar 11, 2007
  • Mar 11, 2007
I had the same problem right after installing new O2's. Changed them a month later back to a pair of stock ones, an the back firing and hesitation stopped.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 11, 2007
  • Mar 11, 2007
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
Resolved Fixing a GT40P Valvetrain nightmare
  • foxbodyclark
  • May 21, 2025
Fox 5.0 Mustang Tech May 24, 2025
limp
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
