I am new here but I have looked through all these forums trying to find an answer to my problem. I own a 89 hatch 5.0 5 speed. I recently purchased it (Saturday night) not running but quickly got it running (Sunday morning) with a fuel pump, fuel filter, ignition switch and battery. I drove it all Sunday working out a few kinks and getting used to the car (Its my first fox) and it ran good. I let it sit over night Sunday and when i woke up Monday, it didn't run. i went to work all day came home and found i had spark but the injectors wouldn't fire. I started at the ignition switch because this was similar to when it was broken but everything seemed to be ok. then I took one injector connection off and tested for power. it has 12v at the red wire. Next I inspected the computer connections and everything looked tight without water damage. The ground on the inner fender near the battery is also connected and has no corrosion. What else do i need to check? Am i over looking something? Thanks in advance!
