89 Saleen hatch
SaleenJoe
Bought this car in may and enjoy the car but miss having a truck so one of the mustangs has to go.
89 Saleen hatch #0448 White with gray flofit interior. Car has 72,XXX miles and miles will go up daily as I drive it daily. Exterior is very clean with no rust. Saleen ARE wheels are in wxcellent shape with BFG rubber that has a good amount of tread left. Interior is in excellent shape . Exterior in great shape car does have a few hail dings on the roof and hood. All vin tags in place with the exception of the hood cause it was replaced.Very rare car, 1 of 7 in white with gray graphics and gray ARE wheels. AC blows ice cold and car doesnt run hot at all in 100 plus degree weather.Crusie works perfect as well. Ground effects have typical road rash which is expected of a 22 year old fox as well as nicks and dents. Car was in an accident at one time cause the passenger door is red under neath, found that out when I pulled the door panel (will get a car fax on the car) Have a loan on the car through wichita federal but they are easy to deal with.
Stock 5.0 with GT40 upper and lower intakes
Cam (believe it is a crane cam)
Motorsport unequal shorties
Off road X pipe into Flowmasters
Saleen strut tower brace.
Kenny brown subframe conectors
Lincoln mark VII rear with disc (done by Saleen)
5 lug (done by Saleen)
SVO master cylinder (done by Saleen)
Hurst shifter with stock handle
Saleen springs with monroe sensatrac shocks
professional products egr spacer and 65mm explorer throttle body
(Bad)
light Hail damage
Scratch on drivers side of windshield
5th gear grind comes and goes.I am going to try and address this before its sold
Couple spots on hatch where paint was touched up at one time
Typical road rash for its age and dings
car had a stripe on it at one tim can see the outline on the roof.
typical fox body seat belt slack.
(Recent parts include)
new TPS
Distributor,cap,rotor
Autolite plugs
02 sensors
motorsport plug wires
ACT sensor
Fresh trans fluid change.
AC low pressure switch and WOT relay
Fan clutch
upper door mouldings
Run channel mouldings
battery cables
Starter
Alternator
Other than that the car is stock and runs awesome. Has all the saleen specific parts in place,momo wheel,saleen shift knob,flofit interior,saleen ground effects
Sale price is
$9k
Dent on drivers side rear fender lip
Paint chip and crack on saleen spoiler
This car does have 72k miles and is 22 years old so keep that in mind. I have underhood pics I will post up later as well.
Rock chips on hood
