I am hearing a "clunking" type noise that seems to be coming from the rear of the car. I have had the car on a lift and made sure that nothing is loose back there. It seems that the noise is progressively getting worse.
While on the lift I rotated the driveshaft and the tires back and forth and there is some slop or play in the rear end. (U joints are solid no play there)
I am not sure how much play I should have?
The noise only occurs when the rear end is not under any kind of load.
During acceleration or under decceleration no noise at all.
But when the car is coasting (no load) without the engine pulling the car up to speed or pulling the car down from speed the noise occurs.
Any thoughts?
Thanks,
Scott
Any thoughts?
Thanks,
Scott
