Hack
Yes, I agree with your logic. Also, I bet you get some kind of warranty. So if something is defective, Currie will fix it. If you do it yourself and mess it up, tough. I would probably end up with the junkyard route, but if I had the money, the credit card would be whipped out...ssppiitt said:at the flywheel I am making 500 HP and 497 ft. lbs of torque. Due to the tranny and other stuff I am lossing about 40 HP by the time it gets to the rear. So I estimate in the end I will have about 450 HP to the rear maybe more after a dyno tune. But even more importantly is that ~4600 ft. lbs. of torque will be hitting the rearend. I have been doing the math and have come to these conclusions. I could get a rearend from a yard for about 100 but most likely the whole 3rd member and axles will have to be replaced as well as it will not come with the pinion support or disc brakes. When you add up all the parts it comes out to almost the same as the currie unit plus I would have to build it myself or have someone else build it for an additional cost. I think I will just end up buying it complete from currie. Atleast I will also have the satisfaction of knowing it will never break and it is being put together by professionals.
Hopefully, I'll have the car finished by the end of this summer. I am also running Wilwoods up front.
