90/10's and 50/50's. How will the ride be on street?
Ride quality is not bad at all, however you will notice the front end jump around a little more when you take off.
Do you still have stock springs, sway bars, etc....the change will be less noticable if so.
It will be fine, if you remove the sway bar it will help plant the tires harder at the track but you will get some body roll in the turns on the street.
yep im running same setup as you and dont even bother ****ing around w/ turns and stuff... the body roll is fun feels like my body is upside down on some of the turns on the highways here..
