90-93 T/B question
yea, if you want to run a fox style (86-93) throttle body on your 94-95, your going to need a fox style throttle cable, throttle cable bracket, egr spacer, throttle body of coarse, and you won't have cruise control, unless you find a way to rig that up.
If you dont go with the FMS t/b, you will also need to re use your old IAC sensor, and bolt it to the new t/b.. other then that your good to go.
