Hi everyone. I am new to the forum and happy to be here. My 90 foxbody, which I bought new in May of 1990, is still in good shape and still has the stock motor with no modifications. Just about a daily driver. That said, a few weeks ago I purchased a megsquirt PNP-2 (MS) and decided to give it a try. I down loaded the starter tune from MS and was able to get it stated using the vaccum line and deleting the MAF and just using SD. (MS suggested) I did manage to get the extreem rich idle under control, with a few table idle fuel adjustments but have not mastered the difficult start.
The timing on the motor is at 14 degrees and the MS is at 14 degrees. When the motor does start, it reves good and holds an idle but does not go through a typical warm up process like the factory A9L.(1200 rpm and levels off at 800). The MS just starts idling at 800 rpm. There may be something incorreclty set here...
I am not looking for a crazy performace tune, just a good start at this point so I can drive the car a little with the MS.
Can anyone offer some suggestions? I can post my tune if that will help.
Thank you.
Wes
Thank you.
Wes
