90 GT vibration
  • Thread starter Thread starter 90stangGTguy
  • Start date Start date Mar 12, 2007
9
90stangGTguy
Apalachin,N.Y
Mar 12, 2007
  • Mar 12, 2007
Someone help. I have a 90 GT 3.73 rear it viberates bad over 60mph.U-joints are all good cant seem to get it .I aso had the drive shaft bal.Im missing the quad shocks in the rear could that be it?Also the rear end sits lower that the front what would cause this? Any help please.
LeKiD
Quebec, Canada
Mar 12, 2007
  • Mar 12, 2007
Rear tailhausing bushing on your trans is probably busted , or your transmission is probably mis-adjusted . Harmonic damper .
85ragtop
BTW, I like dudes.
475
123
NC
Mar 13, 2007
  • Mar 13, 2007
Moved to tech.
V
v8only
2,378
22
49
Mar 13, 2007
  • Mar 13, 2007
r u sure it's speed related and not rpm related?
If you're cruising 60mph, and you push the clutch in, if the vibrations stop, it's somewhere in the motor/trans....if the vibration continues, it's the driveline....first guess would be the tires, make sure they're all balanced right, you also can't adjust a trans for vibrations.
9
90stangGTguy
Apalachin,N.Y
Mar 13, 2007
  • Mar 13, 2007
Thanx ill try those and not is doesnt stop when clutch is desingauged
V
v8only
2,378
22
49
Mar 13, 2007
  • Mar 13, 2007
ok, then since you balanced your shaft, it's somewhere else not in the motor/trans, it's likely tires as mentioned, but could be suspension/rear end too
HISSIN50
34
129
Mar 13, 2007
  • Mar 13, 2007
If you want to go with Jeremy's tire idea, you can rotate the tires and see if the issue follows the tire (if your steering wheel starts shaking badly now, chances are it is a balance issue).
Good luck.
LeKiD
Quebec, Canada
Mar 14, 2007
  • Mar 14, 2007
A transmission with too much end play will defenatly have vibrationn . I tested this fact many times and solve the problem with a good adjusting .
9
90stangGTguy
Apalachin,N.Y
Mar 14, 2007
  • Mar 14, 2007
Thanx for all your help i ll keep u posted
Skoobie
Damn...Tyler65's hot!
May 25, 2003
655
Vancouver, WA
Mar 14, 2007
#10
  • Mar 14, 2007
  • #10
Can someone post up a good way to test for tailshaft end play/bad u-joints? Just jack it up and start reefing on the driveshaft to see if it moves? Is a little play ok? Should there be no play at all?
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
