Electrical 90 lx cant find service port
ReyRey
Texas
I cant seem to find the service port to retrieve codes checked all over engine bay however i did find these loose and cut wires
See if you can find these wires by color
I suspect someone has connected these wires up or just cut them off in an attempt to make the car run.
Is it originally a V8 car?
I found one but I'm guessing it's wrong one it's attached to black connector and it turns to grey w/ red line on other side of connector
Hunt around the web and find some wiring diagrams for the 90 model year, veryuseful.com is a good place to start, I like printed stuff but I'm a little old. You will need to trace that harness to put the port wires back together.
Look for the shape of this connector. Nothing should be plugged into it. It's nothing in your pics.
I see a few cut off wires. Why would anyone cut anything off?
I have looked for that plug my guess is it has been cut off at some point gonna have to find a donor car so I can get that plug and wire it in myself and the wiring diagram is a huge help thanks
You gotta find an old Ford in a junkyard.
If you do, use this splice:
Heat Shrink Solder Sleeve Butt Splice Wire Connector Waterproof
I do not suggest using these anymore after I had multiple failures and was forced to open my wiring harness and replace every one of them. The solder joint would brake and give an intermittent connection, I simple use a cold weld connector and heat shrink all connections now.
There is a repair kit consisting of the plastic connector shell and the necessary short pigtail leads with the terminals crimped on. It is available at Advance Auto Parts or AutoZone or maybe O'Riley's Auto parts. The most difficult thing will be getting the parts person steered in the right place to look it up... Electrical pigtails seems to ring a bell for me...
BWD EEC Test Plug Connector Part # PT763
https://www.autozone.com/catalog/co....com/znetcs/product-info/en/US/wl2/429/image/
Foxbody Diagnostic connector
foxbody-mustang-diagnostic-connector-jpg.586766
Foxbody Diagnostic connector close up view[/b]
foxbody-diagnostic-connetor-closeup-view-jpg.586765
Reactions: ReyRey
