Engine 90 lx won’t run with maf connected
  • Thread starter Thread starter Tp90notch
  • Start date Start date Sep 15, 2019
First Prev 2 of 2
General karthief
Mod Dude
Aug 25, 2016
28,041
10,660
213
polk county florida
Sep 18, 2019
#21
  • Sep 18, 2019
  • #21
Blown88GT said:
Thanks for the props, but one of my jobs was just a bit more complicated than any car.
The one at the bottom for NASA. They only made 1 test aircraft.
This one, too. Designed & build most of the hardware.
High Energy Laser Systems Test Facility (HELSTF)
Mid-Infrared Advanced Chemical Laser (MIRACL)
www.globalsecurity.org
Show off
i guess that means I'm not gonna get you to hang on to a plug wire while I check for spark?
General karthief
Mod Dude
Aug 25, 2016
28,041
10,660
213
polk county florida
Sep 18, 2019
#22
  • Sep 18, 2019
  • #22
Tp90notch said:
Well I respect your knowledge. I’m just here for help. I jumped the connector out and ran the fuel pump. Still only have under 10 psi. Where would my inertia switch be on a notchback?
WTF! Come on dude, you think the inertia switch is gonna give you low fuel pressure?
you can waste your time fart'n around with this or that but unless you do the work it takes to actually diagnose your problem then I don't know what to tell ya.
I can tell ya the inertia switch may be behind the passenger side kick panel (I think) or behind the trim inside the trunk probably on the drivers side or by the inside latch, can't remember.
T
Tp90notch
14
Massachusetts
Sep 18, 2019
#23
  • Sep 18, 2019
  • #23
I’m so damn confused right now. One guy is telling me one thing and the other is telling me another thing. I have little pressure. I have a code 96 which is losing power at some point with the ignition in the run position. Last guy posted a probability fail list in order. Inertia was first. I planned on doing the simple stuff first.
T
Tp90notch
14
Massachusetts
Sep 18, 2019
#24
  • Sep 18, 2019
  • #24
Jrichker literally just posted this:
No fuel pressure-possible failed items in order of probability
1. Tripped inertia switch
Which one of you is actually the expert?
General karthief
Mod Dude
Aug 25, 2016
28,041
10,660
213
polk county florida
Sep 18, 2019
#25
  • Sep 18, 2019
  • #25
Do the checklist, can't go wrong.
General karthief
Mod Dude
Aug 25, 2016
28,041
10,660
213
polk county florida
Sep 18, 2019
#26
  • Sep 18, 2019
  • #26
No expert needed. You have 10 psi right?
Oh, and jrichker is an expert.
I can just read.
Never mind, just continue on and I'll stop reading.
T
Tp90notch
14
Massachusetts
Sep 19, 2019
#27
  • Sep 19, 2019
  • #27
I got 10 psi. I have a code 96 which means I’m losing power at some point with the ignition on. At some point it stops building pressure. I’m losing the pressure. Usually an electrical thing I would think right? Not trying to cause any problems here. I understand our confusion here. But yes I do have pressure but also am losing power at the same time.
General karthief
Mod Dude
Aug 25, 2016
28,041
10,660
213
polk county florida
Sep 19, 2019
#28
  • Sep 19, 2019
  • #28
Do a voltage drop test on the wires going to the fuel pump.
we are here to help, let's get this thing running so you can
First Prev 2 of 2
F
86 notch NEED HELP!!!!
  • foxbody86
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
  • brandyn200
  • Jun 20, 2026
AeroCoupe
G
Persistent P0102 and limp mode
  • Godless
  • Oct 30, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Nov 11, 2025
Godless
G
