jaidedeye said:3k stall is too much for a stock motor
How can you say that,, a 3000 stall is too big for a stock motor!!I have a 2800 stall,and it is a little loose!!!(my motor is all stock. You know when your taking off from a stop(at normal excelleration) and you have to give it a little extra gas pedal to get it going? That shouldnt happen,it means its too big.1990LXDropTop said:No it's not. I had an edge 3000rpm stall in my old 91GT. It made a world of difference. It was a custom converter set up by Andre at Edge.
willys1 said:How can you say that,, a 3000 stall is too big for a stock motor!!I have a 2800 stall,and it is a little loose!!!(my motor is all stock. You know when your taking off from a stop(at normal excelleration) and you have to give it a little extra gas pedal to get it going? That shouldnt happen,it means its too big.
rsw007 said:well you can have a loose 2800 and a tight 3000 stall. there is alot to converter other than stall speed.
We both have a stock cam,and 410 gears!! What else is there?rsw007 said:well you can have a loose 2800 and a tight 3000 stall. there is alot to converter other than stall speed.
