90 Mustang Tries To Die In First Gear
90GTWHITESTANG
Hey Gus kinda new to this forum stuff but I have a question I'm hoping to get help with. I have a 1990 gt mustang 302 and when I put it in first gear and try to take off it starts to buck and act likes its going to shut off until I let of the gas and then it comes right back. It only seems to do this under load, any suggestions?
Does this happen only on a warm engine? If it happens with both a warm and cold engine, do the below items.
1,) Dump the codes stored in the computer.
2.) Do a full tuneup - spark plugs, spark plug wires, distributor cap, rotor, fuel filter if you haven't already done it.
3.) Check the fuel pressure.
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Your 86-88 5.0 won't have a working Check Engine Light, so you'll need a test light.
See AutoZone Part Number: 25886 , $10
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see www.midwayautosupply.com/Equus-Digital-Ford-Code-Reader/dp/B000EW0KHW Equus - Digital Ford Code Reader (3145It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $22-$36.
Check fuel pressure:
The local auto parts store may rent or loan a fuel pressure test gauge if you don't have one.
Disconnect the vacuum line from the fuel pressure regulator. Check it for evidence of fuel present in the line by removing it and blowing air through it. If you find fuel, the fuel pressure regulator has failed. Reinstall the line; leave the fuel pressure regulator end of the vacuum line disconnected. Then cap or plug the open end of the vacuum line and stow it out of the way.
Connect the fuel pressure test gauge to the Schrader port located just behind the alternator.
Turn the ignition switch on & start the engine. Observe the pressure: you should see 37-41 PSI at idle.
Turn the ignition off; reconnect the vacuum line to the fuel pressure regulator. Then disconnect the fuel pressure test gauge. Watch out for squirting gas when you do this.
This problem happens on both a warm and cold engine, the strange thing about it is the car was wrecked when I bought it and it ran great for three months and I just took it to my body work guy and he did all the body work I needed and then when I went to pick up the car a week later I had this problem the car idles great and I can rev it up no problem but as soon as its in gear and I start to take off it starts bucking real hard and acts like its going to die. I thought he may have shorted a wire some where and I went through it and couldn't find anything obvious, and I'm wondering if this could be a distributor problem or the pip sensor? And should I just replace the whole distributor with a stock oem one
It had a fresh tune up on it three months ago when I bought it with MSD ignition parts and has barely been drove in that time due to the body damage and as soon as I get all that fixed now the car won't run when trying to take off in gear
Check the distributor cap for signs of moisture and carbon tracks.
Wait until it is dark and spray a water mist using a squirt bottle around the spark plug wires. A blue glow or spark jumping is a sign of bad spark plug wires.
MSD means May Suddenly Die. I see more problems here on Stangnet with MSD than any other manufacturer.
The stock ignition parts are better in terms of reliability and quality. The stock ignition will work satisfactorily up to 400 HP on engines that do not have NO2 or pressurized induction.
Reactions: 90GTWHITESTANG
Did you check the codes and did you run a cylinder balance test? You might as well let the car tell you what it sees is wrong. Otherwise we are making guesses, some better than others.
Besides the obvious spark and fuel, the wild idea that popped up in my brainstorm is an EGR system that is not functioning right. But check the codes before diving into that one.
Ok thanks I will check to see if there is any codes befor I get to much involved and the car does have a nitrious system in it which I have yet to use and plan on taking out because its a dry system, ill get back to you after checking those things and see what I find thanks again
