90 vs. 91 Computer
  • Thread starter Thread starter Black Sun 5.0
  • Start date Start date Mar 17, 2008
Black Sun 5.0
1,337
L.I., N.Y.
Mar 17, 2008
  • Mar 17, 2008
OK, so I swapped my engine from a manual '91 to an automatic '90 and then swapped to manual on the '90. Should I be experiencing any computer problems as a result? I'm doing some troubleshooting on this thing.
vristang
4,933
101
124
Seattle
Mar 17, 2008
  • Mar 17, 2008
swapping 90 to 91 shouldn't cause any running issues
swapping auto to manual shouldn't cause any running issues
What kind of problems are you having?
Do you get any Diagnostic codes?
Black Sun 5.0
1,337
L.I., N.Y.
Mar 17, 2008
  • Mar 17, 2008
I actually got to the point that I brought the car to my mechanic and he had questions for me, specifically about the computer. Apparently, they can't connect to it to run codes.
D
DrMaxit
139
Augsta GA
Mar 17, 2008
  • Mar 17, 2008
For some reason I couldn't get our 6000 dollar Snap-On scanner to pull the codes on my car, but I can manually pull them with the LED technique. See if you can pull your own codes. But to answer your question you shouldn't have a problem swapping the ecu.
--Chuck
Flushing water from the radiator and block.
  • djj62478
  • Oct 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 11, 2026
CAMTWO1070
Fox Rear Seat Belts - 87-89 vs 90-93 length
  • dan50
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
Mustang5L5
Stuck
  • bshipley
  • Aug 27, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 28, 2026
squeak93
D
Yet another v8 swap
  • dulcimerbob
  • Sep 19, 2026
  • 4 5 6
3K
1974 - 1978 Mustang II Talk & Tech Nov 10, 2026
LILCBRA
Engine How to identify EEC-IV
  • keel
  • Aug 17, 2025
Fox 5.0 Mustang Tech Sep 1, 2025
