90's tbird 8.8
snowb07
235
soon to be CT
I can get a 90's tbird IRS for cheap and I am wondering if anyone has any information on them. Would I be able to use this rearend in my 68 fastback. would it be to wide or narrow. Any more information would be helpful
The Tbirds had IRS... ever ? Also, I thought the 5 lug Tbirds had the same bolt patern as the Mustang ?
What year car did this come out of and with what engine ?
Too wide, and wrong bolt circle pattern.
Yes, but not so wide that you couldn't fix that problem with a non-stock wheel backspacing.
If it has the early 4 lug pattern, that's more of a problem. With a 8.8 solid rear you can swap in Ranger axles, but for this unit that's not an option. I'm sure you can overcome it, but I don't know how or what the cost would be. I wouldn't encourage anyone to run rear 4 lugs and front 5 lugs.
I have a 91' Thunderbird. While it is a 7.5 over a 8.8, it is still a 5 lug and I couldn't imagine where you would start to put that in the 65 mustang I got. You would need a ton of new mounting points and other custom parts.
The gear housing actually bolts the the frame of the car in the middle, where the gas tank would be on a mustang (the thunderbird tank is under the rear passenger seat).
Like mentioned above, it can be done, but at what cost?
The Mustang I saw done was the IRS from a late Stang and the whole thing was mounted under the late Stangs in a cradle, 4 bolts, remove the driveshaft and brake lines and roll it out from under the car. It was retrofitted to a 67 Stang fastback along with a DOHC 4.6. The front two mounting points aligned with two holes in the 67's frame and the rear just needed two angle brackets to bolt onto the rear mount points. (or it was vice-versa, it's been about 3-4 years since I saw the article)
The bolt circle issue is easily solved by using some Cobra IRS hubs. That's what T-bird guys do when upgrading their brakes, wheels etc.
Here are a bunch of pics:
http://www.mn12performance.com/mn12how-to/irs/irs.html
On another site, I found that the width (hub-hub) is 63.25" for a Lincoln IRS, T Bird is probably the same. That's 4" wider than a 68 rearend. A lot of BS would be needed, but beware that although late model Mustang wheels have 1.5-2" more BS than, say, most vintage 15x7 wheels, they're also an inch wider, so the front of the rim moves only 0.5-1" more inwards.
I still say it's too much work. The Cobra hubs will work on it, but then you also need Cobra rotors and custom brackets for mounting the calipers. As for the front, everyone that I've seen using the late model wheels with big backspacing has had to use 1 1/4" spacers in order to clear the upper control arm.
the t-bird IRS is totally different from the mustang unit. completely different cradle system, different weaker axles, the bolt pattern difference already mentioned and the shock/spring mounting points are different too. it could be done and made to work but it's not very practical at all and it's still too wide for a 65-66 car.
