91 Mustang Efi Issues
MustangMando
107
Hi guys,
I dropped a 302 efi from a 91 in my 68 mustang, put a tanks fuel tank with intank fuel pump. Fuel pressures holds steady at 40psi. When i drive the car it bucks and feels like it has no power. The car also idles rough and fluctuates. Ive checked the firing order and its right. Please give me some advise on how and where to start. Everything is stock, thanks. When I bought donor car it drove fine. Took out the 302 and rebuilt it with a ford tech (friend which is always busy). I dropped the engine in my. 68 and drove good and strong with an occasional sputter or hiccup. The sputter became more and more. I changed the fuel system to a Tanks inc setup. Fuel pressure stays at 40 psi. I disconnected the tps and drove it around the block and stilled bucked. I disconnected the mass air flow sensor and drove it and still did the same. I did transfer the map sensor too. My wiring harness is custom rjm harness so it's not rigged. The car idles like s**t. What else should I diagnose? It also smells rich
I think im narrowing it down, changed the coil its not the coil. Its not the TFI either. I put an inline spark tester and noticed its ignition related. Sparked kept cutting off under load. Any other tips??
Madspeed, my ignition is from a 68 stang and alternator from a 68 also, but motor, ecu, starter is from a 91 mustang. I have noticed that a green wire marked alt is not connected?? May not mean anything but just want to give out any info
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Your 86-88 5.0 won't have a working Check Engine Light, so you'll need a test light.
See AutoZone Part Number: 25886 , $10
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see www.midwayautosupply.com/Equus-Digital-Ford-Code-Reader/dp/B000EW0KHW Equus - Digital Ford Code Reader (3145It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $22-$36.
