65ShelbyClone
ouch there goes that idea in my 65but what about fuel mileage with a 2.3T?
There is guy over on turboford.org that put one in a '65 notchback. It will still improve handling because the 2.3 is shorter and can be set closer to the firewall. I can just about climb in front of the SVO's engine. An aluminum head like Esslinger sells will help weight. A Volvo swap is good for a lot more power, but requires a fair bit of fabrication and IMO is not for the faint of heart. Custom pistons, welding the head, tuning the EFI, and scratch building an intake and exhaust come to mind. I personally would rather just start with a Zetec or Duratec.
There have been reports of economy in the low to mid 30s with the Turbo Coupes, but that is more of a best case scenario. Mustangs are lower due to the aerodynamics and an early one will be lower yet. The most I was able to get out of my SVO was about 26, but some of the engine sensors are going south. fixing them should bring the mileage up to ~28-30mpg. That and recutting the leaky valves. Head is probably cracked through the seats anyway, most 2.3T heads are.
Then again, it has a shell, only 114hp, and only weighs 2560lbs.
