92 weird problems lights starter
  • Thread starter Thread starter mus50
  • Start date Start date Nov 29, 2011
M
mus50
  • Nov 29, 2011
I just bought a 92 5.0 lx, Was unaware of all the problems the dashlights come on with the igntion switch, also the parking an taillights come on very dim with the key on, But all lights work good an bright if you turn the lights on brakelights and blinkers seem fine.And everytime i start it the starter stays engaged for 2 seconds after it starts, Tried starting it with a screwdriver at the solinoid samething, Put new starter an solonoid on today samething, checked battery and grounds underhood also this car was converted from a auto, to a manual, the guy i bought it from works at the ford place he said it was the starter, Now i'm thinking he sold it because he couldn't fix it where Should i start with this mess ?
M
mus50
  • Nov 30, 2011
I just checked the wire going to the starter solnoid, and the solnoid on the fenderwell both go out soon as i release the key, checking with test lite, Online search says that rules out the ing. switch, Bought the starter at napa, Should i try another solinoid ? also found out the the starter will turn over without mashing the clutch in shouldn.t there be a safetey switch so the clutch has to be mashed in before starter engauges ?
M
mus50
  • Nov 30, 2011
Got the starter problem fixed, did a search here and found that the starter relay was wired wrong, Now if i can figure out the lights the parking lights bright an dim with the dashlight dimmer switch,Anybody had that problem ?
2000xp8
SN Certified Technician
Aug 8, 2003
8,068
1,655
194
NJ
Dec 2, 2011
  • Dec 2, 2011
Did you fix the clutch safety issue? That would be a priority IMO, only bad things can happen when a car is willing to start without the clutch pushed in.
With the lights, are you saying that normally they work fine, just not when the car is running?
M
mus50
  • Dec 2, 2011
Got the lights fixed who ever put the radio in, wired the blue/red wire from the dimmer switch, in with the power wire,
J
  • JRC99
  • Apr 19, 2025
JRC99
J
D
Double check my electrical diagnosis of light issues on 65 Coupe
  • Duke City Novice
  • Jan 21, 2024
1965 - 1973 Classic Mustangs -General/Talk- Feb 4, 2024
AeroCoupe
L
Engine 97 mustang gt manual weird idol when off the throttle and coasting in 3rd, 4th, or 5th
  • Lanezs
  • Jun 9, 2023
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
J
Electrical No crank no dash no nothing, troubleshooting leads to more questions
  • Jojam99
  • Jun 2, 2022
  • 1994 - 1995 Specific Tech
3K
1994 - 1995 Specific Tech Jun 2, 2022
Jojam99
J
2004 Mach 1 crank but no start. dying inside
  • gavinmgrant
  • May 23, 2022
  • 2 3
10K
SN95 4.6L Mustang Tech Jun 11, 2022
Mach1.0
M
