93 4cyl 5 speed trans....into 92 5.0
598LX
Iam new to fox mustangs and dont know much about the transmissions i have a 93 coupe 4 cyl with 5 speed trans iam putting an all aluminum 598 c460 headed motor in the 93 coupe and need to know if the transmission will work with my 5.0 92 limeted edition vert i also own a 94 GT i dont want to throw it away later to find out its the same as whats in my 92 5.0 vert
thanks Rich..
Iam pulling the 4 cyl drive line out of the 93 coupe and putting a big block in it with a rollerized c4 35 spline 9 inch rearend is there is there anything on the 4 cyl 5 speed trans that will interchange with the 5 speed 5.0 trans that i could use on my 92 5.0 stang sorry for the confusion..
thanks Rich..
Lets try this again what are you trying to do??? If you mean a 2.3, T-5 behind a V-8....I don't think it will even bolt up....and if it did, it will NEVER handle the power of a V-8!!
The 5.0 tranny and the 4-cyl tanny are a little different, the 4-cyl being weaker due to the input shaft. You would need the smaller pilot bearing to fit the 4-cyl tranny, but it would bolt right up with the proper bell housing. I don't think it would last long with the torque of a big block, if I'm reading you right..
the 4 cyl t-5 is different from a v-8 but will fit and run with the 5.0. If you put too much power to it though then it will fail. You will need to change out the pilot roller bearing in the 5.0 and fit it with the 4 cyl one since the input shaft on the tranny is smaller. and use the 5.0 bellhousing I believe.
EDIT- sorry, I didn't see the above. Ourobos looks to have it correct
Thank's for to info..
I will sell it with rest of the 4 cyl driveline
Rich.S
92 5.0 vert limited edition -stock
93 coupe soon to get a aluminum 598 ci pump gas motor
94 GT-stock
