- Dec 31, 2006
- 5
- 0
- 0
My brother was driving his 93 5.0 that he just bought a few days ago down the road and all of the sudden it dies on him. He finally figured out a little while later after messing with it that if he started it and then held the key forward then it would stay running and he got it home like this... If you return the key to the normal position then the car dies, but if you keep it just inbetween the normal on position and the START position (but making sure that the starter is off) then it will stay running. He was told that it was the ignition switch so he went and got a new one (the little part that plugs up on the bottom and uses 2 tork screws to hold it on). We replaced this part and THEN the damn thing won't even stay running using that trick. It would not start at all, but just keep cranking. SO then he went back and got the whole tumbler setup for another 10 bucks and we got the damn steering wheel off (WHY THE HELL WOULD THEY DO THAT that way?!) and replaced it and after we put that all back in... NOW It will start and run for about 2 seconds before studdering and then dying. This is more than it did before, but it still dies everytime.
DOES ANYBODY HAVE ANY CLUES?!
on the ignition switch to go into)
