93 Cobra Mass air and Injectors???
I've never heard that the maf was calibrated for 19's and that the computer "changed it". If you're after the larger diameter, just change the sensor on the top from your old one to the cobra one or get the injectors to match the maf sensor and then change your fuel pressure to match or get a chip thats burned for the 24lbers.
:stupid:
I was going to buy a cobra mass air and injector set. If it is true then it seems that it wouldn't work with my computer. I know I have heard people using Cobra mass airs with 19lb injectors.
In simple terms, the Cobra EEC adjusts for the 24# injectors.
The Cobra meter is "calibrated" for a Cobra EEC (X3Z) with 24# injectors. The Cobra mass air transfer function (kg/hr vs volts) happens to be similar to the stock GT (A9L) transfer function so a Cobra meter "almost" works with 19s and an A9L. But the transfer function is different so it's far less than an ideal solution.
