93 Factory CD Player, Stuck CD
  • Thread starter Thread starter 5literPwr
  • Start date Start date May 5, 2004
5literPwr
122
May 5, 2004
  • May 5, 2004
I did a search on this topic and was unable to find a solution. My 93 factory cd player will not eject a cd from my stereo. The cd is stuck inside of the unit, and will not eject out. I would be interested in discovering a method to get the cd out without breaking my stereo, and was hoping someone may know the solution. Thanks in advance.
85GTlover
704
  • May 5, 2004
try disconnecting your battery this will cut power to the stereo
(well the whole car too) then see, it may eject it when it repowers.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 5, 2004
  • May 5, 2004
SuperStang83
1,693
Boyertown, Pa
May 5, 2004
  • May 5, 2004
That's what I would try. It has worked for me before on aftermarket head units!
Jakob
blk92stangg
583
Hawaii
May 6, 2004
  • May 6, 2004
There should be a reset button too you could try.
5literPwr
122
May 6, 2004
  • May 6, 2004
Thanks for all the input everyone. Unfortunantly, disconnecting the power from the car didnt work. I thought it would work, but after disco'ing the battery, the cd remained stuck in the unit when the power was restored to the car. Blk92stangg, I tried pressing multiple buttons on the unit to see if anything would work, but I dont recall seeing a reset button. I will check again right now and see if i can find it. Thanks again.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 6, 2004
  • May 6, 2004
Time to break out the needle nose pliars, I guess....or get used to listening to only one CD?
5literPwr
122
May 6, 2004
  • May 6, 2004
Darn, didnt see a reset button. Gearbanger 101, yea i thought about that idea already, but the space is so tight i couldnt fit pliers into it. I was hoping to be able to keep the stock cd player in the car, but looks like i may have to end up getting another unit. I'm sure a new factory ford unit is priced way high, so looks like I will have to find a non-flashy, stock-looking cd unit now. Thanks again to everyone for your input.
blk92stangg
583
Hawaii
May 9, 2004
  • May 9, 2004
If you do have a reset button, it will be a super small hole, one that you would need a pin or something thin to push it...it won't look like a button at all, and it probably won't be labeled either. If you get a new one, I would suggest investing a bit more and getting one that plays mp3s and WMA files. I can get hours of music on 1 cd, and its great.
wythors
Get off my lawn!!!
2,277
35
69
C Addle
May 9, 2004
#10
  • May 9, 2004
  • #10
If you pull the unit out, the top of it can be popped off. Your CD will be right on top of everything. Its been so long since this happened to me that I can't remember exactly how its laid out, but there is a lever that you can slide back and it releases the CD. Good luck.
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
R
1974 Datsun 620 pickup / 5.0L HO
  • RJH46
  • Aug 24, 2025
  • Other Auto Tech
Other Auto Tech Aug 24, 2025
T
Need advice: 93 Cobra audio upgrade with no permanent modifications
  • THNX SVT
  • Feb 18, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 20, 2024
TIGGER
Fuel 87 5.0 Fuel rail lines
  • Mcmahst
  • Jan 21, 2025
Fox 5.0 Mustang Tech Feb 11, 2025
Mcmahst
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
