Suspension 93 fox gt
Nightstang00
133
12
28
What specs do we go by when aligning the cars. I have caster/camber plates from Maximum Motorsports, and I sn95 spindles. I hear from others that it’s not stock specs since the plates are there. Any info?
You can align to stock specs with the MM plates if you wanted. The MM plates just correct a few issues when you lower a stock fox and can't align back to stock specs. But once installed there is nothing preventing you from doing a stock alignment on the car with the MM plates.
MM recommends some different specs in their install directions, mainly dialing in a little extra caster which is lacking on the fox cars. You may want to consider aligning to their specs or even adding in a bit more camber depending on your driving style.
Bigger issue is finding a shop that will align to anything other than stock specs for liability reasons.
Ok that sounds better. Do you happen to know the specs?
