93 lx fuel pump relay location?
erzats
74
My son has a 93 lx came in this morning said car had run out of gas. We put about 4 gallons in and now when we turn the key the pump will not prime no sound coming from it at all car cranks strong but seems like no fuel . opened the little fuel line valve while he cranked and got no fuel at all. I know there is a relay under the seat of the 91 but where is it in the 93? help please.
Switch the relays and see if it works. You should feel a click when you turn the key on. If you do feel the click then check with a light at the fuel pump plug and make sure you are getting power to the pump. It's probably the pump. If you run the pump dry it can fry it, not always but I've seen a few instances.
