Was wondering if this blue print motor would work good with a on3 turbo kit
Specifications
Hand picked seasoned block
Square and parallel decked
Align honed main bearing bore
Cylinders honed on computer controlled machine to within .0002 straightness and roundness
Cylinders are sonic tested for thickness
2-bolt main
4.000" Bored .040" over
1-piece rear main seal
Rotating Assembly
New BluePrint cast steel crankshaft
3.250" stroke
Forged I-beam 5.400" connecting rods
Hypereutectic pistons
28oz external balance
Cylinder Heads
BluePrint Aluminum Cylinder Heads- HP9008
60cc chamber
2.02" intake/ 1.60" exhaust valves
190cc intake/65cc exhaust runners
Camshaft
Roller
.543 Intake .554 Exhuast
218 Intake / 226 Exhaust duration
@ .050 - 112 degree LSA
Specifications
- Brand: BluePrint Engines
- Part Number: BP3313CTF
- 375 HP / 405 FT LBS
- 9.5:1 Compression Ratio
2-bolt main
Rotating Assembly
3.250" stroke
Cylinder Heads
60cc chamber
Camshaft
Roller
