94opalgt....
The EGR.....I run no smog, so that hose for the EGR is gone....(these are the Red/Green lines that run to your smog stuff and into the fenderwell....plug em both good, and stash em in the fender..
The tube on top WOULD feed the oil fill tube, just like your 95 has a tube that feeds it...you dont need it....plug it....the cap I used can be found in most parts stores..
I was intent of a Fox swap so I knew the issues...Its not all that much money to get the hardware and a TB...like I said, I knew that going into it...
The intake sensor is for coolant temp...Your Cobra one uses the same set-up...I THINK the Foxes ran another sensor in that intake port, forgot what its name is??? But the 95 does not have that sensor...it's another style and place on our cars..
Under the upper....the Cobra used a "vac tree" for lack of a better explaination for all the feeds...its a large tube that threads into the hole you speak of... it then "tree's"...one main tube and 2 smaller ones...
..when getting a 93 style its always nice to have it...you'll have to fab something up I guess or locate one...I have not seen them for sale, nor do I know if Ford can get it for you???
You only require (4) vac feeds...the pcv feeds into the other tube on the lower....from the "tree" you feed (1) line to your vac Tee on the drivers fender, by the brake booster...(1) line to your FPR..(1) for the purge can sloeniod...thats it for vac lines...
The EGR...when you undo the electrical plug off the EGR a long plunger comes out...secure this to its 1/2 position...this will keep the light off...
Hope that helps you out some...
