Wheels-Tires 94-04 rims swap onto 2011?
scarter302
Boxboro, MA
Got a 2011 GT without brembos but with 19" rims. Do the 94-04 rims fit this? I have snow tires on 17x9 bullet wheels from my last mustang. just wondering if these will swap out without hitting any parts or brake components. Or else they'll just go on craigslist.
I think there are some differences between the 94-04 rims; has to do with backspacing IIRC. You might try going on American Muscle and finding the rims you have and seeing if the computer will let you put them on your 2011. Other than that, you'll just have to give it a shot to see if they fit, unless someone else can pipe in here.
they'll physically fit but the offset is different. All this means is you won't be able to bolt quite as wide a tire onto those rims as you might if you had the the 05+ backspacing. Not really an issue with snows. Anything factory 16"+ will bolt up no problem also.
