94-95 Cobra mass air
5.0guy7
I have a 94 GT, and I was going to upgrade to 24lb injectors while I had the intake off. Can I use a mass air off of a 94-95 Cobra, what else will I need to do to make it work?
Thanks!
Jackie Chan said:
why are you upgrading the injectors? unless you have a full top end there is no reason
true. i have the whole top end and im still using 19's. hey john, nice times. how much of a shot are you running. i just picked up a dry kit and some drag radials. im hoping for similar times when i get my 60' times down a little bit.
What I am getting ready to install is GT40 upper and lower intake and GT40P heads off of a 1997 explorer, slight port work on the heads with 1.6 RR and a cam. What cam would work best with that setup when using 3.73 gears with an AODE? Also will I be ok with stock MAF, TB and 19# injectors?
yes you will be ok with the stock maf to tb stuff and injectors. i know plenty of guys with the stock stuff above running deep 12's. would they improve if they swapped them? yes. but your money will be better spent on susp or tires or even better N2O
the 19's can handle that mild h/c/i, but it is pushing the upper limits of what the injectors can handle. i would suggest moving up to 24's especially if you take the advice to get ANY type of nitrous kit.
