94-95 Electric fan wiring
  • Thread starter Thread starter nick6690
  • Start date Start date Mar 15, 2011
nick6690
147
McDonough, GA
Mar 15, 2011
  • Mar 15, 2011
Can someone with a 94-95 Mustang fan, or any other single fan setup explain how you wired your fan? I keep blowing 30 amp fuses with my setup now, I'm just tired of messing with it and I want it to be legit. Thanks for any help!
87AODGT
373
Toms River, NJ
Mar 15, 2011
  • Mar 15, 2011
you need to get a maxi fuse and a holder for it, they take the initial fan startup amp spike far better than the little terd fuses
nick6690
147
McDonough, GA
Mar 15, 2011
  • Mar 15, 2011
Could you give me a link for one? I have no idea what you're talking about haha but thanks man.
HISSIN50
34
129
Mar 15, 2011
  • Mar 15, 2011
They look kinda like a supersized blade fuse.
FWIW, the OEM circuit protection in 94-95's is a 60 AMP fuse as I recall.
Fusible link is another option. It might be easier to implement.
nick6690
147
McDonough, GA
Mar 16, 2011
  • Mar 16, 2011
What gauge wire would you guys recommend using?
4rdnut
188
  • Mar 16, 2011
What kind of fan controller are you using, you need one that slowly brings the fan speed up to 100 percent so you dont have that big amp surge at spin up or turn on. The cheap controllers turn the fans on at full power which causes blown fuses and arcing terminal connections, make sure all your connections are soldered, crimped terminals will eventually arc and blow fuses. oem electric fans are amp pigs, thats why i went with a flexalite black magic extreme #185 fan with an amp draw of 18 amps. I have a mild 340 hp motor so this fan serves me well. I can sit in traffic here in virginia and the temp gauge stays right at 198 degrees.
Mustang5L5
Mod Dude
Feb 18, 2001
43,349
18,085
224
Massachusetts
Mar 16, 2011
  • Mar 16, 2011
You need a 60a maxi-fuse for that fan.
KcMstang
1,563
Hamilton, Georgia
Oct 6, 2016
  • Oct 6, 2016
My fan is currently tapped into the #17 fuse. It worked fine since I bought the car (2years) and now blowing the 30amp fuses. Will wiring the maxi fuse in line help?
HISSIN50
34
129
Oct 6, 2016
  • Oct 6, 2016
What year/trim? If your sig is accurate, you might wanna try the S197 sub-forum. If not, more info is needed.
KcMstang
1,563
Hamilton, Georgia
Oct 6, 2016
#10
  • Oct 6, 2016
  • #10
1994 Mustang GT.
HISSIN50
34
129
Oct 6, 2016
#11
  • Oct 6, 2016
  • #11
KcMstang said:
1994 Mustang GT.
For clarity, your fan control is tapped into CCRM Pin 17, yes? [The assumption is you installed a switch to ground on Pin 17].
Pin 17 is only for fan control, not powering the fan.
As I recall, the fan's power circuit is protected with a 60 amp fuse, not 30.
Have you any reason to believe the fan motor is starting to seize? Does your car have a circuit breaker near the fan connector? Have you pulled the fan connector to see if it started to melt?
In case you happen to have tried this: If you apply 12V to CCRM Pin 14, does the low-speed spool up without blowing a fuse?
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
Engine Which cooling part first?
  • Dontknowchit
  • May 8, 2025
Fox 5.0 Mustang Tech May 15, 2025
90trunk
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
