94 and 99 cobra suspension swap??
vennom
111
Does anyone know if the 94 cobra/gt suspension is fairly swapable with a 99 cobra irs? I am looking into this swap and I would be greatful for anyones knoledge or experence. Thanks for your help.
Vennom
OK cheif im doing this exact swap as we speak. try to find a 2003-04 cobra IRS cause they come stock with 3.55 gears and stronger halfshafts, and pinion stabilizer bar. or you could go with a 99' to 01' what ever you desire.
its basically a staright bold on. you only need to drill 4 holes. the Front mounts of the IRS go right into where your lower control arms on an live axel will rest. and then jack it up until you find the rear upper mounts. (you can do this will the front is bolted up to the frame). make sure have the rear upper mounting braqkets from ford!!!!!!
email me if you need any more help
There is a little more work involved for the 94-98 vs the 99+ solid axle. Where are you located? I know a guy around Raliegh that is wanting to swap a '00 solid for an IRS. You'd have to drive to him but he has a garage with a lift and all the tools you'll need.
99SVTAddict said:
It would be much easier to do a 99+ solid swap. The pre 99's are 1.5 inches shorter, but can mount up.
That's the short answer.
Do you mean shorter in the driveshaft? and I would need to buy mounting brackets from ford. . .right? will they know what im talking about.
I live near seattle so Raeilgh is a little far to drive. . lol.
Anyway thanks for the help
vennom
Meaning that they are 1.5 inches shorter side to side...your tires will be tucked in. Besides, do you really want an old axle put into your Cobra :shrug: Go with a 99+ axle so the trade is a little more equeal. If you do swap for a pre 99 suspension, you better being getting some money on top of your trade.
The guy already has some suspension pieces on it maybe an exhaust system and some gears will make it a fair trade? If it is good condition then would their be a problem.
