94 cobra will not crank
walter24892
:shrug:I have a 94 cobra, when I bought the car there was no battery tray in the car, the batter was tied down with a bungie cord. As I was taking the car home the battery came untied fell over the hot post grounded out on the aluminum part of the power steering hose the car died completely. I try to start the car back it would not crank if I push start the car and pop the clutch it will start and run but when I turn the key I hear a click but the starter will not rotate I have no clue if its a fusible link or what if anyone could help it would be greatly appreciated. Thanks:shrug::shrug::shrug::shrug:
you may have killed the battery, have it and the charging stytem tested. if all is good alot of the time a solid click is the sound the starting solinoid makes when bad. if its a rapid click than it can be a dead battery or a loose wire. if you have a test light it will make finding the problem alot smoother.
