'94 dizzy and a msd box with carberator?
94Blue302GT
704
Chicago
Correct me if i'm wrong, but im planning on doing a motor swap with my '94 into my 66, but putting the intake and 750 carb on it.
Can I use the 94's dizzy and just get a MSD 6AL or similar to run it correctly, or is it more worth my while to get a vaccuum advance dizzy for it? The 94's is brand new, so i'd like to use it, and an msd box may be beneficial anyways, I just didn't know if it can be done that way.
Thanks.
Blu3
You cannot use the '94 distributor without a computer to control the timing.
Sounds like you should be swapping to a duraspark distributor from a mid-80's engine.
So.... the MSD 6AL doesn't take place of the computer in regards to timing? I thought it did that for me and then was adjustable as well.
If that's the case, i'll just buy a new dizzy with vaccuum advance.
Will have the E-cam, afr 185's, edelbrock dual plane, edel 750, long tubes(unsure which ones yet) and stroking to 331 since i'll have it out. That's why the 750 not the 600
