  • 1994 - 1995 Specific Tech
94 GT 5.0 performance problem help
  • Thread starter Thread starter bflynn
  • Start date Start date Jan 21, 2006
bflynn
  • Jan 21, 2006
My 94 GT 5.0 statring having a problem. In low gears it is the most noticeable. It feels like I am pulling and lead anchor, it just won't go. I am getting about 50 miles per tank less on fuel milage. Top end seems to still be there. If I kick it into passing gear, it just ups the rpm's and does not acclerate. I have had it tuned up, replaced the catalytic converters, the oxygens sensors. It is better but I can still be beat at low end by hondas. Just prior to replacing the 2 O2 sensors, I was receiving the following codes. Any ideas what my problem is?
172 Oxygen sensor not switching - system is or was lean - Single, Right or Rear HO2S - Fuel control
176 Oxygen sensor not switching - system is or was lean Left or Front HO2S - Fuel control
181 Fuel system was lean at part throttle Single, Right or Rear HO2S - Fuel control
189 Fuel system was lean at part throttle - Left or Front HO2S - Fuel control
bill302
2,131
alabama,gadsden
Jan 21, 2006
  • Jan 21, 2006
sounds like your tranny is slipping in low gears.
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Jan 21, 2006
  • Jan 21, 2006
If you have an adjustable fuel regulator you need to up the fuel pressure a few psi. Clear the codes and go run it hard. If your still getting lean codes then keep turning it up. I had the same issue some time ago. I use to have a nasty lean pop at high rpm's. If you don't have one your car is telling you to get one.
bill302
2,131
alabama,gadsden
Jan 21, 2006
  • Jan 21, 2006
oh ya welcome to :SNSign:
DoctorB712
71
Montreal
Jan 22, 2006
  • Jan 22, 2006
I'm not 100% sure but I had lean codes last summer. Someone told me to clean the MAF sensor with air intake cleaner. Did it and gone. For 5$ and 15 minutes it was worth it. I dont remember the exact code but it sounded like yours!
Hope it helps
CManT1914
3,172
Killeen, Texas
Jan 22, 2006
  • Jan 22, 2006
I think we really need some information on what he has done to his engine. Is it stock?
droptopford 5 0
427
Jan 23, 2006
  • Jan 23, 2006
Hope it helps
its probably more in depth than this, but my low end gave out on me, my mpg went down and i was throwing the 189 code when my MAF was dirty, just spray some electronic contact cleaner on the little wires inside the MAF, its worth doing wither way if you havnt done that yet, even if you dont think this is the problem. oh ya, i was also getting a part throttle ping as time went on with this problem. good luck wither way
G
Help! 93 Mustang 2.3L A4LD dies at idle
  • goofyfoot53
  • Nov 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
goofyfoot53
G
M
Progress Thread 1993 Ford Mustang 5.0 convertible stock manual - ODB Codes shows running lean
  • mcalvo
  • Feb 11, 2025
2K
Fox 5.0 Mustang Tech Feb 22, 2025
AeroCoupe
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
  • dan50
  • Jul 18, 2026
dan50
