  • 1994 - 1995 Specific Tech
94 Gt Sputter Issue
  • Thread starter Thread starter Hunter Pannell
  • Start date Start date Aug 14, 2017
H
Hunter Pannell
9
  • Aug 14, 2017
Hello. So I have recently bought this stang and there is a situation going on with it. I've owned it for 2 weeks now and CAN NOT figure out why this thing is sputtering!
Let me explain:
1st gear to 2nd does fine. No problems
2nd gear to 3rd there is a hesitation of a "sputter" before going into 3rd.
3rd to 4th really no issue.
4th to 5th """
Now 5th gear any speed it's the worst! If I'm cruising down the highway going 65. It's like its misfiring in a way. But it's way more of a sputter, and it's not just a one time deal. If I hold the gas down at 65 it will continually do it.
I have changed the ignition coil, cleaned MAF sensor and plug that goes into the harness, checked plugs for gas, wires are fine too.
I have researched all forums I can find but there have been no solution replies or they are having a rough idle which I don't.
The car idles great no hesitation or miss. It's only doing it while driving. Any information will greatly be appreciated!
General karthief
20+ Year Stangneter
Aug 25, 2016
27,929
10,573
203
polk county florida
Aug 14, 2017
  • Aug 14, 2017
Run the codes,
https://www.stangnet.com/mustang-fo...codes-from-eec4-in-86-95-5-0-mustangs.889006/
This thread will show you how, post the codes
Any modifications?
H
Hunter Pannell
9
  • Aug 14, 2017
karthief said:
Run the codes,
Any modifications?
No mods. Bone stock. Still has smog pump as well.
*edit: I will have to get codes tomorrow. But thanks for that link.
General karthief
20+ Year Stangneter
Aug 25, 2016
27,929
10,573
203
polk county florida
Aug 14, 2017
  • Aug 14, 2017
Bone stock has advantages, you don't have to figuare out/fix botched junk.
Reactions: Hunter Pannell
H
Hunter Pannell
9
  • Aug 15, 2017
Yeah it definitely does. It does have flomaster exhaust that I know of. But that's the only mods I know about
H
Hunter Pannell
9
  • Aug 15, 2017
Update
Have not yet gotten a scanner. Will probably be Friday until I can.
jozsefsz
1,243
332
124
Cleveland OH Area
Aug 15, 2017
  • Aug 15, 2017
Checking codes is good. I'd also check fuel pressure and timing - those won't directly show up us codes but both can cause sputtering at high load.
H
Hunter Pannell
9
  • Aug 16, 2017
Ok thanks. I've heard to check my timing, but what are you considering a high load?
General karthief
20+ Year Stangneter
Aug 25, 2016
27,929
10,573
203
polk county florida
Aug 16, 2017
  • Aug 16, 2017
Accelerating from low rpms like being in 4th gear at 35 mph going up hill or speeding up from 55mph in 5th.
H
Hunter Pannell
9
#10
  • Aug 16, 2017
  • #10
If I have the gas I would say 1/4 to 1/2 throttle to what your saying it will. But if the pedal is fully engaged it won't do it.
H
Hunter Pannell
9
#11
  • Aug 16, 2017
  • #11
I have also done a quick test on the MAF sensor. While engine running at normal temp, I unplugged the sensor and the motor did not hesitate it stayed running. Thoughts??
I've heard that means the MAF sensor is bad but am not sure with these late model mustangs.
Also to add to timing: I have noticed that my idle rpm is 1k. I feel it should be lower than that. Not to mention when I have the clutch engaged the rpms will rise from 1800-2500 I'm not sure if that's part of an issue I'm dealing with at the moment but that is rather aggravating as well.
General karthief
20+ Year Stangneter
Aug 25, 2016
27,929
10,573
203
polk county florida
Aug 16, 2017
#12
  • Aug 16, 2017
  • #12
Can't tell you anything for sure until you check for codes, your just guessing. Don't chase your tail, one thing at atime.
H
Hunter Pannell
9
#13
  • Aug 16, 2017
  • #13
Oh I know. I've seen it done thousands of times through forums I have read. I'm gonna try to get me a scanner and I'll get back with y'all after that
Reactions: General karthief
H
Hunter Pannell
9
#14
  • Aug 21, 2017
  • #14
Update
I got my hands on a code scanner that displays the 3 digit codes. I ran the KOEO test came back for a FPR malfunction. So I changed that out. For some reason the scanner won't allow me to do KOER test so I can't get the full codes. Idk if it's because I don't have the clutch in or what but I'm going to mess with it some more this week. However, the fpr made a huge improvement but the problem still exist. That was the only code worth mentioning, other codes were having to do with transmission temp and bad shifting solenoid that I already knew about
9
95gt1985
Virginia
Oct 19, 2024
#15
  • Oct 19, 2024
  • #15
Hunter Pannell said:
Update
What was the fix to the issue?
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Jun 14, 2026
Mindseye007
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 20, 2026
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
C
1967 Mustang 5.0 swapped shuddering/sputtering issues
  • Cro67
  • Sep 24, 2025
  • Fox Engine Swaparoo
Fox Engine Swaparoo Sep 25, 2025
General karthief
C
Trans issues.
  • ChrisCruz1972
  • Aug 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
slow84lx
