'94 GT steering rack swap....
krtw
43
Oregon
I FINALLY found an SPR-ZM (03-04 cobra) rack for my '94. My question is, when switching to the new rack what fluid should I use. Normally I'd use Type F, not sure if that should change. I am wondering if the type of fluid is more dependant on the pump and not the rack. I know some of you have done this swap so hopefully you can answer this question..... Thanks!!!
Type F ATF. That is what they recommend for the 94-95 mustangs. I used it again in my new SPR-ZM rack, I tend to think it has more to do with the Pump than the rack.....but I could be wrong. Anyways, I got the new rack installed, I tested it Saturday night and it works great. I also replaced the steering shaft with an MM shaft. The steering feels much better :D, no more dead spot at center. I will test it some more once it stops raining.....I did an alignment myself but will need to get it to an alignment shop at some point.
what advantages does the cobra rack have?
Its a tighter tolerance rack. They reduced the gear backlash and decreased the turns ratio. I can't find the original articles, when the 2003 Cobra was first reviewed they mentioned these improvements over the standard steering racks in the GT cars. I wanted one because I had annoying play in my steering, a dead spot at center. I found nothing really wrong with the steering components (steering shaft, rag joint, etc...). At first I ordered a reman standard rack and installed it, nothing changed...same issue. So I did some searching and found out about the 03-04 cobra racks (SPR-ZM). With the new SPR-ZM rack and the MM steering shaft my steering feels perfect.
where did you find the rack at? and the cobra rack has a tighter turn ratio.
I found mine at my local Ford Dealer, I was really surprised to find one. I searched the internet and never found a real one, they have gotten rare. Actually I thought I had found one on the net and I ordered it through rackpinionwhse.com, but they tried to pull a fast one and sent me a different rack....I think they do this on purpose. They substituted the ZM rack with a ZK rack and they still charged me for the ZM rack. I called them and found they don't even carry the ZM rack..... On the phone they tried to argue with me about how the ZK rack would fit.....which of course I knew it would fit but its not what I ordered or paid for. I got my money back. You have been warned.
for that price it better drive it's self!
i ended up picking up a cobra rack from MPS off ebay. only 28k miles on it. When i called the local dealerships they said they could get them from the warehouse but it would be $270. Got this one for $200 shipped. Hopefully it comes in this week.
