  • 1994 - 1995 Specific Tech
94 stroker, solving idle problems?
  • Thread starter Thread starter Tonyu47
  • Start date Start date Mar 5, 2010
T
Tonyu47
Albuquerque NM
Mar 5, 2010
  • Mar 5, 2010
Hey guys,
I want to swap a 331 for my 94 cobra engine, has anyone seen a stroker sorted out for stable idle, etc. with a J4J1 computer?
I plan to build it with AFR 185 60cc heads, Fordstrokers 331 short block, tmoss GT40 lower, and a custom grind from Compcams. I already have a quarterhorse in it and LC-1. Any advice on who or where to get idle tuning info particular to the 94/95 computers would be greatly appreciated.
thanks,
TonyL
Bosko5.0
1,067
longwood, FL
Mar 7, 2010
  • Mar 7, 2010
Any tuning shop should be able to get you a nice idle.
BlackVert
5,589
9
98
Bethesda, MD
Mar 7, 2010
  • Mar 7, 2010
of course a stroker can have a good idle. mine idles nicely at 700 with lots of lope. it is all in the tune.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Mar 7, 2010
  • Mar 7, 2010
I'll hit the high spots
but
You'll need to fill in the blanks with your own research
A good place to do it is here with a search
but
You will have to go back as far as 2 to 3 years ago
We were way more active with all the tuning stuff back then :Word:
Another place for tuning info is eectuning.org
First thing is to get a suitable meter and a transfer curve loaded for it
Then raise your idle to 900 rpm to start out with
Next I would start off adding about 15% to idle values such as
Throttle Body Airflow
Neutral Idle Airflow
also ... See what peeps are using for ISC Duty Cycle these days
That should get you started
Grady
T
Tonyu47
Albuquerque NM
Mar 7, 2010
  • Mar 7, 2010
thanks guys
My engine builder said it wouldn't idle right with a 94 PCM, which I didn't think was entirely true, but meant I needed to get some advice from folks who had gotten it to work.
Thanks for the feedback. I have searched the old posts but did not find too many details specific to strokers. Now I have a better picture and some leads on tuning shops if tuning myself does not work out [thanks Kurt].
cheers,
TonyL
ProKiller
3,064
15
78
PA
Mar 8, 2010
  • Mar 8, 2010
it won't idle good right out of the gate no. The cam specs should be more your concern not the fact that it is a stroker.
95riosnake
630
Pittsburgh, PA
Mar 8, 2010
  • Mar 8, 2010
Get an SCT 4 bank chip and have it tuned on a dyno and it will be fine. Make sure to use a good quality mass air meter, I used a C&L and regret it, I'm going with a lightning maf this time around (on a 347) which will give me a nice 800-900 rpm idle with no surging or hanging idle.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Mar 8, 2010
  • Mar 8, 2010
cheers,
TonyL
Hello Tony
Stroker or Not ... as far as idle issues ............
The principles are gonna be the same
so
Any info on a h\c\i combo will be applicable to your concerns
:Word: You D O N ' T want your engine builder tuning for you :Word:
Grady
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Mar 8, 2010
  • Mar 8, 2010
what maf and injectors are you going to run ?
T
Tonyu47
Albuquerque NM
Mar 9, 2010
#10
  • Mar 9, 2010
  • #10
I have 24# now with the stock cobra MAF. I don't have room for a bigger MAF so the intake track up to the TB is what it is for now. I am getting a 70mm TB and a Tmoss ported GT40 lower. I have some 30# injectors I can use if I am maxing out the 24's.
I think my cam will turn out close to a Compcams XE264HR [#35-320-8] as camquest6 seems to pick that one for many of the combinations I tried:
0.544 lift
212 I 218 E duration at 0.050
112 lobe centers
I have found lots of info on calibrating MAF transfer functions and injector slopes so I am not too concerned about dialing them in, but idle tuning is a bit more complicated so I am more concerned about getting a good understanding of it.
cheers,
TonyL
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Mar 9, 2010
#11
  • Mar 9, 2010
  • #11
You most likely already know this but
The first thing you wanna do is load in your additional cubic inches :Word:
That will change your load factors and you would not wanna do a bunch
of tuning and then plug in your values for the larger motor cause then
the tuning you did for OEM motor size would not be accurate
Grady
Progress Thread H/C Swap Problems/Ideas
  • sav22rem22
  • Mar 31, 2024
2K
Fox 5.0 Mustang Tech Sep 10, 2024
AeroCoupe
Cam Advice For A Supercharged 331 Stroker
  • blotte1
  • Sep 30, 2016
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 30, 2016
blotte1
M
  • Locked
Expired 1990 Mustang Coupe - 347 Stroker - 75% Complete Project, Drives Great - $5000 (north Port, Fl)
  • mkkoller717
  • Aug 17, 2013
7K
Fox Body Mustangs For Sale (1979-93) Aug 17, 2013
mkkoller717
M
T
88gt with a 94-95 engine. Wiring issues, amongst other problems
  • Thgzfrlife
  • Jul 21, 2011
4K
Fox 5.0 Mustang Tech Jul 21, 2011
jrichker
Spring 2009 Build
  • klaw
  • Jun 15, 2009
  • 2005 - 2009 Specific Tech
3K
2005 - 2009 Specific Tech Jun 16, 2009
lexluthr69
