  • SN95 V6 Mustang Tech
94 V6 Oil Pump?
  • Thread starter Thread starter psycho78
  • Start date Start date Mar 28, 2010
P
psycho78
32
Tampa, FL
Mar 28, 2010
  • Mar 28, 2010
Im thinking of going to look at a used 94 Mustang tomorrow that the price is right on, but Im told it def' needs an oil pump. How difficult is this procedure? Im not probably going to do it myself, Im just wondering if its a major thing to where it wouldnt be economically viable to even get the car?
MustangLX-5.0
856
Lehigh Acres Fla.
Mar 29, 2010
  • Mar 29, 2010
Like the 5.0, you have to remove the front crossmember before you can remove the oil pan. I'm not sure what all is involved in that.
Are you sure the oil pump is bad? Did you start it up and listen? You may want to do that, listen for any unusual knocking noises. Check the gauge. Many times people think the oil pump or some other oil flow problem has occured, when actually it was just a faulty oil pressure sender switch. Those senders have a habit of going bad.... very often.I replaced mine twice, and after 2 years, it's going out again. I would check to make sure. The seller might think the oil pump is going out if its only a faulty sender. Find out the exact specifics. And just in case it IS just a sender, don't tell them what you think you may know, otherwise they're liable to jack the price up.... hint hint.
D
97 V6 suspension upgrades
  • Dale1bre
  • Jan 18, 2026
SN95 V6 Mustang Tech Jan 19, 2026
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
2005 4.0 V6 Convertible Anti Theft Issue
  • Brysen
  • Dec 7, 2024
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Dec 7, 2024
General karthief
M
  • mnky99
  • Sep 5, 2025
mnky99
M
