  • 1994 - 1995 Specific Tech
94'Gt timing question.
  • Thread starter Thread starter Darrin
  • Start date Start date Jun 13, 2004
Darrin
184
Cocoa, Florida
Jun 13, 2004
  • Jun 13, 2004
O.k. 94'Gt. Is the timing spout connector the one located by the maf meter?
The reason I ask is...My car had been loosing power and started the detonation clacking crap. I looked for the spout connector and found only one by the maf sensor. I pulled it and set the timing to dead on. Replace it and the spark knock is still there. Put 93 octane in it and runs perfect. filled with 87 and noise. Checked timing again....dead on. Help
moneypit94
1,723
Macomb, IL
Jun 13, 2004
  • Jun 13, 2004
yes that is the spout wire... And if you had that plugged in while trying to time it you would know. It would be all over the place up towards 20* and higher... What did you set the timing at?
RIO5.0
6,892
N.H.
Jun 13, 2004
  • Jun 13, 2004
Yes, you found the spout.....Sounds like systems normal to me....either run 93 or back the timing down more if you wanna use 87....Hows the balancer??? high milage car and it could be off some....
Darrin
184
Cocoa, Florida
Jun 13, 2004
  • Jun 13, 2004
set it at 10 deg. Only 97000 miles.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jun 14, 2004
  • Jun 14, 2004
My car is detonating just like yours it (10* timing also). When it's cold out, the detonation pretty much goes away. But when it's hot, there is nothing I can do about it. I have to run 91 octane or else it will detonate really bad.
Some people have had luck with a few fixes. Clean the MAF, replace the ECT/IAT sensor, run combustion chamber cleaner, replaced the fuel filter, check the fuel pressure, etc. So far, none of these have worked for me.
You can try any of the above, but you may have the same results that I have had.
Scott
SuperDust22
The Power of Pixie Dust?!
Oct 19, 2003
1,821
Gilbert,AZ
Jun 14, 2004
  • Jun 14, 2004
My car was detonating too. I put timing to 8 degrees. That's only becuase I live arizona and it is like 115 here. I have still have some cracking sounds. It might be the EGR.
xYoung347x
382
  • Jun 14, 2004
I dont mean to hijack your thread but which way is advance and retard again?
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
