  • SVT Tech Forum
95 Cobra Flywheel / 95 GT Flywheel : IS THERE A DIFFERENCE?
  • Thread starter Thread starter fiveoho
  • Start date Start date Mar 23, 2007
fiveoho
1,958
TN
Mar 23, 2007
  • Mar 23, 2007
i posted the same thread in the 94/95 and after i did i thought you guys could help me. i apologize for the double post but am desperate for help and answers. thank you
ford dealerships show two different part #'s but cant tell me if they are any different because they can only go back 10 years?
after my T5 to cobra T5 swap, i have vibration. if the car is in neutral or the clutch is depressed and i give throttle and i feel vibration, is that the flywheel? it also does it going down the road. seems to change with rpm.
i just had the cobra flywheel resurfaced b4 the swap. could the flywheel be bad? could the machine shop have screwed up? could i have screwed up?
can i just buy a new GT flywheel?
does anyone know if there is a weight difference in two???????????
please help
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Mar 27, 2007
  • Mar 27, 2007
I had the two sitting right next to each other one time. I could not see any difference in the teeth, or the surface itself. I noticed the back side...which faces the engine....had a little bit different look to it....but not enough to make a difference I wouldn't think. I didn't even think to weight them....sorry.
GToddyT5
553
Hamilton, NJ
Mar 27, 2007
  • Mar 27, 2007
Well I would wonder how the different engines are balanced.
fiveoho
1,958
TN
Mar 27, 2007
  • Mar 27, 2007
thats alright.
so from what u could tell, they are very close. visually anyway. both are suppose to be 50oz.....i thought.
i just ordered a new FMS OEM replacement 50oz flywheel from summit. i pray this will solve my problem
94CobraPace
907
Houston, Tx.
Mar 27, 2007
  • Mar 27, 2007
Both the GT & Cobra's are 50 oz balance. They are interchangable. The only difference is the Cobra total weight is a little less than the GT's, only 3 lbs lighter in total weight, not the balance weight.
The one you got from Summit will work, even if it is for a fox. I have a fox billet flywheel on my Cobra.
fiveoho
1,958
TN
Mar 27, 2007
  • Mar 27, 2007
awesome. thanks man
sweet car BTW
SVT32VDOHC
3,501
28
119
Motor City
Mar 28, 2007
  • Mar 28, 2007
fiveoho said:
thats alright.
Yes, visially they looked the same overall, besides the face that faces the engine.
R
rbtmarshall
Michigan
Apr 20, 2007
  • Apr 20, 2007
I have a '95 Cobra; Last year I ordered a clutch + aluminum flywheel along with a few other parts from summit. I was putting together my order on their website, had my order ready to place and decided to give their tech department a call just to be sure i was ordering the right parts. Well, while talking to tech support they told me that I was going to order the wrong flywheel; it wasn't for the Cobra. He gave me a part number to enter into their search and it pulled up the correct flywheel. (the part number he gave me was only found when I manually entered the number, it wasnt showing up on their part list from browser)
I would suggest giving the tech department a call before placing your order, just to be safe.
fiveoho
1,958
TN
Apr 22, 2007
  • Apr 22, 2007
thanks man. i went back to doube check what i ordered. the frrp 50 oz wheel i ordered calls for 81-01 sbf windsor and all 86-95 mustangs as a oem direct replacement.
hope im right...or summit it right
http://store.summitracing.com/partd...62434+4294908331+4294924755+4294840126+400070
2muchtime
890
MA.
Apr 23, 2007
#10
  • Apr 23, 2007
  • #10
please help
why do you think its the flywheel?? because you put in a cobra tranny, doesnt mean you need a cobra flywheel.. only the guts in the tranny are different..
im guessing you bought a used tranny?? yes?
fiveoho
1,958
TN
Apr 23, 2007
#11
  • Apr 23, 2007
  • #11
it vibrates while sitting still in gear or out also while driving. clutch in or out. flywheel is always turning, so thats why.
i didnt know if i needed a cobra fw or not, that was the whole reason for my post. was not sure if there was any difference. several other threads i have read and posted, some still stay there is a difference. summit and parts store all call for the same replacement fw as 50 oz.
the guts in the tranny are the same as a gt with the exception of phosphate coated gearsets.
trans is used yes
F
fordflashback
#12
  • Apr 23, 2007
  • #12
Do any of you guys have a stock 94-95 Cobra flywheel you want to sell? Thanks, Ron
fiveoho
1,958
TN
Apr 23, 2007
#13
  • Apr 23, 2007
  • #13
i would sell you the 95 cobra flywheel that i just replaced but here's what you need to know about it:
i bought it used and had it resurfaced. i installed it along with a different trans and i had vibration. i replaced it with a new flywheel i bought and most of the vibration went away but i still have some. there is about 25 miles on the resurfacing. i would sell it to you but just wanted to be up front.
im not sure if the flywheel has a problem or something else in my setup does. i have a new flywheel now and still have some vibration so i assume its something else.
all this has taken place within the last 6 weeks
let me know if you are interested
F
fordflashback
#14
  • Apr 23, 2007
  • #14
Thanks fiveoho, yes I'm interested. I sent you a PM. Any others out there?...we will need probably two or three of these flywheels.
Thanks, Ron http://dearbornflashback.com
fiveoho
1,958
TN
Apr 23, 2007
#15
  • Apr 23, 2007
  • #15
sent u a pm
D
Drivetrain Using a 98 Cobra T45 in a 03 GT Auto
  • dylan9075
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
dylan9075
D
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
  • SVT Tech Forum
