- Nov 27, 2001
- 89
- 0
- 0
Just recently my car started having problems. It won't accelerate past 2.5-3k RPM. In neutral it won't rev past 4k. MASSIVE power loss. It doesn't misfire when easy on the throttle but if i try to punch it (which is pointless anyways) i can feel it misfiring. Tested with a new coil no difference. Tested TPS voltage and it was fine. Have a new MAF (old one went bad about 6 months ago) Has a new cap/rotor. No CEL is on or flashing or has turned on. The rear cat on passenger side does have a dent in it from when backing down a driveway and it hit the curb. I'm thinking the honeycomb broke and the cat's clogged and causing excessive backpressure, but i'm not sure. any other ideas?
The car does have a Ford RPM Extender modified for Cobras but i don't think it's that because with extender disconnected car won't start so i would figure same thing would happen if it went bad.
Thanks
Edit: Also when going uphill i can barely get past 30-40mph just cuz of the RPM issue and also the engine temp starts to rise pretty quickly (doesn't overheat) but defiantly hotter then it should be especially with how cold it is outside.
Thanks
