  • 1994 - 1995 Specific Tech
95 Cobra = Stalls
  • Thread starter Thread starter Labora
  • Start date Start date Apr 25, 2008
First Prev 2 of 2
hollywoodstang
1,095
May 1, 2008
#21
  • May 1, 2008
  • #21
Simple solution; "SELL" your cobra to me and i will take care of the problem, Then you can go buy "BETTER" condition cobra or GT.
There you go man
Labora
1,855
26
69
Dallas, Texas
May 1, 2008
#22
  • May 1, 2008
  • #22
You don't want my car for more reasons then I care to list.. :I
BlackVert
5,589
9
98
Bethesda, MD
May 1, 2008
#23
  • May 1, 2008
  • #23
There you go man
lol ... if you want to buy a stang, buy mine
hollywoodstang
1,095
May 1, 2008
#24
  • May 1, 2008
  • #24
I have never thought of this until TODAY!!!! may be it is your FPR
try: REPLACE YOUR FUEL PRESSURE REGULATOR!!! Mine failed me today and it stalls and buckling...It is brand new kirban 3 days old. and failed me...
hollywoodstang
1,095
May 1, 2008
#25
  • May 1, 2008
  • #25
Nevermind. Now i have problem as well...LMAO. You got me cursed
Labora
1,855
26
69
Dallas, Texas
May 4, 2008
#26
  • May 4, 2008
  • #26
Ok so today I went out and tinkered with it some more.
First I drove it until it got hot to recreate the problem. Luckily I got home without the slightest issue not even 3mins after I park it from returning home (still running) it stalls out and won't restart.
Anyhow.
You can hear the injectors clicking and they have power. Is there a correct way to test these?
Coil has 12v with key on, no spark @ spark plug wires coil puts out weak spark on initial hit of the key.
HISSIN50
34
129
May 4, 2008
#27
  • May 4, 2008
  • #27
A noid light tests the electrical side of the injector.
If the quality of spark deteriorates as a function of time or engine heat (which is how electrical items often fail), consider swapping in a fresh coil. The weak spark indicates that the PIP and TFI are functional and sending a signal.
Now if you find that the injectors are not clicking or dont have consistant power across them (remember, 12 volts is constant, ground is modulated) and the spark ever completely goes away, that's when you have to consider the PIP and/or TFI.
Based on what you said, it sounds like a weak coil.
Labora
1,855
26
69
Dallas, Texas
May 4, 2008
#28
  • May 4, 2008
  • #28
Coil is new, but hey so is everything else so what the hell...
Anyhow will a foxbody coil work. (I assume it would) If so I'll borrow a friends.
Thanks for any advice. :SNSign:
HISSIN50
34
129
May 5, 2008
#29
  • May 5, 2008
  • #29
A foxbody coil should work fine. Half the coils for that era of Fords are the same.
Labora
1,855
26
69
Dallas, Texas
May 7, 2008
#30
  • May 7, 2008
  • #30
Swapped with foxbody coil did not solve the problem. I'm really considering ordering a MSD dist so I can rule out crappy parts store parts but they are kinda pricey last time I looked....
donkey_punch
565
northern****ingjersey
May 7, 2008
#31
  • May 7, 2008
  • #31
i have an MSD billet dizzy and it only put a band aid on the stalling. it wasn't long before it went back to the same thing. so save your money.
i also read that the reman dizzy are garbage also. and it was recomended to rebuild the dizzy with ford parts. which is what i'm about to do.
btw what brand of TB do you have?
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
May 7, 2008
#32
  • May 7, 2008
  • #32
Has anyone suggested checking the grounds for the engine? The stock ground wire is hooked up to the driver's motor mount and goes to the frame rail. You may want to add another ground from the passenger motor mount to the frame on that side.
I'd also check the power connector on that side. Isn't there some sort of a capacitor attached to the side of the coil mount? I'd also check where the coil mounts to the bracket, make sure the screws are clean and tight.
EDIT: The ground wire can get corroded, might be worth replacing the ground wire completely. I replaced mine with one I got at my local parts shop, it was in the battery section. Dunno what gauge it was, anyone have a recommendation?
First Prev 2 of 2
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Engine 1988 Ford Mustang throwing 2 OBD-1 codes (32 and 63) rough cold start and initial idle
  • mikeah
  • Nov 16, 2026
Fox 5.0 Mustang Tech Nov 17, 2026
mikeah
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
