Call me crazy, but I can't seem to find out where the reservoir is to top up fluid for the top motor.
I have a leak either from the connection on the cylinder(top end) or from the brass fitting where the rubber line goes in. I can't really tell.
I've tightened up the connection because it seemed a little loose, but I want to make sure there is enough fluid to run the thing properly and hopefully have fixed the problem.
I also can't find any resources/help on the convertible model. I've got the Haynes manual, but its got nothing. So if anyone has any suggestions, that would be fantastic!!
Thanks for your help!
