- Jul 8, 2015
- 21
- 2
- 13
My car has the Mach 460 stereo with a cd player. I don't think it is a 100% factory installation because it has only a single play Ford factory cd player, and the lower area that normally holds the cassette player is just a storage compartment. I bought the car in 1997 with 1200 miles on it, from a dealer, and it came that way. It has worked fine for years, but recently there is a popping sound when I turn up the volume. I don't know if it is the volume control knob, or if the speakers are finally shot. My question is, does anyone know if I can replace the speakers or head unit with newer, non Ford equipment, or is the factory stuff all that will work? I know from the factory it had several amps, and for a factory stereo from 20 years ago it was pretty amazing. I just don't know if this system can be upgraded like most normal modern cars because of the additional amps, etc.
if you want to replace OEM speakers. I decided not to replace them. I added an aftermarket head until, mono block AMP, and a CAP (probably 10 years ago
). Recently upgraded my head unit to bluetooth so I can use my phone and take calls handsfree. If you're new to car stereos you may want to pay someone to do the install. If you are confident and want to do it yourself, before you wire anything draw out a diagram! Then you have a plan and a roadmap before things get messy.
