i have a 95 lightning 351that im about to put in my 92 foxbody, the only issue is its a late model 351 and it has a dipstick provision on the block itself. id like to reuse that dipstick spot. are there any swap pans and oil pan gaskets that allow this? i see the stock 95 351 pan gasket has a circular cutout where the dipstick goes. which pan should i get to swap to a foxbody and how would i go about using the original dipstick coming out of the block location? also id like to be able to use a main cap girdle, but if i cant that's fine, im going to do main studs anyway. thanks
