- Nov 24, 2012
- 2
- 0
- 1
Hi all, I think I got a decent problem and could use some ideas. The car is 95 5.0 stock short block, stock cam, Typhoon intake, TFS 170 heads, 1.6 rockers, tnw nitrous plate, 255lb fuel pump, BBK fuel reg. and shorty headers, NO egr, cruise, PS, AC.
I bought the following parts from a road track sn95 part out, bbk fuel reg, t4m0 computer, 30lb injectors, and c&l 76mm maf. I ran the computer and fuel reg last summer on my stock 5.0 no problems. yesterday I wanted to bump my fuel pressure for the new mods. Come to see its set at 70psi! So I change it to 40psi, short test drive I get popping out the exhaust, no acceleration, severe bogging barely able to run under any load. so I change it back to 70psi. Acceleration is decent no bogging no exhaust popping cruises ok but acts like it could use a tune(expected).
the computer is untuned per previous owner. The only idea I have left is the computer has to be tuned. I tried the 30lb and c&l with correct sample tube but couldn't get it to idle(before I I changed to fuel pressure). I'm thinking the next step would be to set the fuel pressure to 38psi and swap back to the 30lb and c&l. Just to throw some more on it I cant pull codes because it wont connect but that's a problem for another day. Any thoughts??
