95 mustang gt
rickyt1
Hey people i was wondering if anyone knows wherei can purchase hubcentric spacers and also why my foglights will not work on my stang. I checked fuses and relays plus check to see if connectivity is going to the switch and sure enough it is. so someone can help with that. if also knows any club in Los angles for stangs let me know. thanks
Check to see if you're getting juice at the fog light sockets. I had non working lights one time and it turned out to be some goobered up sockets, cleaned them and it worked fine. Also, check to see if there's any power from the switch when it's on.
Hubcentric spacers can be found on Ebay or Maximum Motorsports.
What did your relay testing show? That tells you which direction to go based upon the readings of each terminal.
