went to start my 96 Cobra for 1st time in a month. Fired right up and died. Tried starting again and nothing, starter started whining like an electric drill and car sounded like it slipped timing.
Fuel pressure is great, good spark and tried 3 different batteries.
Pulled starter out and found the bendix was staying in the engaged position.
Decided to check compression and it was low, around 60 psi, also found ALL cylinders soaked with fuel, all of them had fuel sitting on top of pistons.
Tried a leak down test but am confused with results. I even pull the drivers valve cover off to make sure that we had it on compression stroke. when I did it on 1, 2, 5 and 7 cylinders I get leaking out of intake manifold and different spark plug holes. I absolutely know when we tried teh leak down test on 1 and 2 we were on dead side of cam but they still leaked into the intake manifold.
Jump timing?? When I roll crank to timing mark the primary sprocket on cam is lined up where it should and is correct as far as i can tell to when the valves should be on #1.
So, will a bad starter crank slow and produce bad compression reults? why do all cylinders tested leak into intake manifold so bad??
